Learn how to automate the creation of viral tweets using RSS feeds with Pabbly Connect, Google Gemini, and X (formerly Twitter). Step-by-step tutorial included. This comprehensive guide reveals exactly how to connect your applications and automate repetitive tasks — accessible for professionals of all technical backgrounds.
To start automating tweet generation, first access Pabbly Connect by navigating to its homepage. Here, you can either sign in if you are an existing user or click on the ‘Sign up for free’ button to create a new account.
Once logged in, you will be directed to the dashboard of Pabbly Connect, where you can manage your workflows. This platform allows you to automate tasks between various applications without any coding skills.
To create a new workflow, click on the ‘Create Workflow’ button. You will be prompted to name your workflow. For this tutorial, name it ‘Automatically Generate Tweets Using Google Gemini from RSS Feeds’. using Pabbly Connect
  • Select the folder where you want to save the workflow.
  • Click on ‘Create’ to finalize your workflow setup.
After creating the workflow, you will see two sections: trigger and action. The trigger will determine when the automation starts, while the action will specify what happens next.
In this step, select ‘RSS by Pabbly’ as your trigger application. The trigger event will be set to ‘New Item in Feed’, which captures new RSS feed updates.
Enter the feed URL from NDTV’s technology RSS feed to receive updates. This connection allows Pabbly Connect to check for new items every hour, ensuring that you get the latest news automatically.
  • Set the polling time to 1 hour.
  • Click on ‘Save and Send Test Request’ to verify the connection.
Once the connection is successful, you will receive the latest feed response, which confirms that your RSS feed is connected to Pabbly Connect.
4. Converting RSS Feed to Tweet Using Google Gemini
Next, set up the action application by selecting ‘Google Gemini’. The action event should be set to ‘Generate Content’. This step involves connecting Pabbly Connect to Google Gemini to convert the RSS feed into engaging tweets.
To establish this connection, you will need to enter your API key from Google Gemini. To obtain the API key, log into your Google Gemini account, navigate to Google AI Studio, and create a new API key.
Copy the API key and paste it into Pabbly Connect. Enter the prompt for generating tweets based on the RSS feed description.
After setting up the text and model, click on ‘Save and Send Test Request’. You will receive a response with the generated tweet, confirming that the conversion is successful.
5. Posting the Tweet on X (Formerly Twitter)
For the final step, select ‘X’ as your action application and set the action event to ‘Create Tweet’. This allows Pabbly Connect to post the generated tweet on your X handle automatically.
To connect X with Pabbly Connect, you will need your client ID and client secret. These can be obtained from the Twitter developer portal by creating a new app or using an existing one.
Paste the client ID and client secret into Pabbly Connect. Authorize the app to allow posting.
Once the connection is established, map the generated tweet text from Google Gemini to the tweet message field and click on ‘Save and Send Test Request’. Your tweet will be posted on your X handle, successfully completing the automation process.
By following these steps, you can automate the process of generating viral tweets using RSS feeds with Pabbly Connect. This integration allows you to keep your followers updated with the latest technology news effortlessly.
