Learn how to automatically share Blogger posts on Discord using Pabbly Connect. Follow this detailed step-by-step tutorial for seamless integration. Discover hidden automation capabilities within your existing tools. This guide shows you how to connect your essential applications and permanently eliminate redundant manual processes.
1. Setting Up Pabbly Connect for Blogger and Discord Integration
To automatically share Blogger posts on Discord, you will first need to set up Pabbly Connect. Start by visiting the Pabbly Connect website.
If you don’t have an account, click on the ‘Sign up for free’ button. This process takes just a couple of minutes, and you will receive 100 free tasks every month. If you already have an account, simply sign in.
Once logged in, you will be directed to the Pabbly Connect dashboard. Here, click on the ‘Create Workflow’ button to initiate your integration.
When prompted, name your workflow something descriptive, like ‘Automatically Share Blogger Posts on Discord.’ You can select a folder to save this workflow, for example, a folder named ‘Discord.’ Click ‘Create’ to proceed.
  • Click on ‘Create Workflow’
  • Name your workflow
  • Select a folder for organization
Now you will see two boxes labeled ‘Trigger’ and ‘Action’. The trigger is the first step that will execute in your workflow, so you’ll need to set that up first using Pabbly Connect.
3. Configuring the Trigger for Google Blogger
In the trigger section, search for and select ‘Google Blogger’ as your application. Next, you will need to choose a trigger event. For this integration, select ‘New Post Added’.
Now, click on the ‘Connect’ button to establish a connection between Google Blogger and Pabbly Connect. You will need to sign in with your Google account and grant the necessary permissions.
  • Select ‘Google Blogger’
  • Choose ‘New Post Added’ as the trigger event
  • Authenticate your Google account
After a successful connection, you’ll need to select your blog ID and set the status to ‘only live’ to ensure you only get details of live posts. This setup is crucial for the automation to work seamlessly.
4. Creating the Action to Send Messages to Discord
After configuring the trigger, it’s time to set up the action. Search for ‘Discord’ in the action application section. The action event you want to select is ‘Send Channel Message’.
Click on ‘Connect’ to link your Discord account to Pabbly Connect. You will need a webhook URL to send messages to your Discord channel. To get this, go to your Discord channel, click on ‘Edit Channel’, and navigate to ‘Integrations’. Here, create a webhook and copy the URL provided.
Select ‘Discord’ Choose ‘Send Channel Message’ Create a webhook in Discord and copy the URL
Paste the webhook URL back into Pabbly Connect and compose your message. You can include dynamic content such as the blog title and URL by mapping them from the trigger response.
5. Testing the Integration and Finalizing the Setup
Once you have set up the message, click on the ‘Save and Send Test’ button. This will send a test message to your Discord channel to confirm that everything is working correctly.
After testing, check your Discord channel to see if the message appears. If successful, you will receive a positive response in Pabbly Connect, indicating that your integration is correctly set up.
Click ‘Save and Send Test’ Verify the message in Discord Receive confirmation in Pabbly Connect
Now you have successfully created an automation that shares new Blogger posts automatically on your Discord channel using Pabbly Connect. This integration will save you time and keep your community updated with your latest content.
Using Pabbly Connect allows you to automate the sharing of Blogger posts on your Discord channel effortlessly. By following the steps outlined, you can keep your community engaged with fresh content without manual effort.
