Learn how to automate adding registrants to your workshop when payment is received using Pabbly Connect with Razorpay and Zoom integration. Learn to create powerful connections between your critical applications without requiring specialized programming knowledge or extensive technical background.
Setting Up Pabbly Connect for Razorpay and Zoom Integration
To automate adding registrants to your workshop when payment is received, start by accessing Pabbly Connect. This platform facilitates seamless integration between Razorpay and Zoom, allowing you to manage payments and registrations effortlessly.
Log into your Pabbly Connect account and navigate to the dashboard. Here, you can create a new workflow that will connect Razorpay with Zoom. This setup will ensure that every time a payment is received, a registrant is automatically added to your Zoom workshop.
Creating a New Workflow in Pabbly Connect
In this section, you will create a new workflow in Pabbly Connect for the integration. Click on the ‘Create Workflow’ button and give it a suitable name, like ‘Razorpay to Zoom Integration’.
Next, select Razorpay as the trigger application. You will need to choose the trigger event, which is ‘Payment Received’. This event will initiate the workflow each time a payment is confirmed. After setting the trigger, you will be prompted to connect your Razorpay account to Pabbly Connect.
Configuring Razorpay in Pabbly Connect
Once the Razorpay account is connected, you will need to configure the trigger settings in Pabbly Connect. This involves specifying the payment details that you want to capture, such as the amount and the payer’s email address.
After configuring the trigger, test it to make sure it captures the payment details correctly. This step is crucial as it ensures that the data will flow correctly into the next step of the workflow. Once verified, you can proceed to the next part of the integration.
Adding Registrant to Zoom Using Pabbly Connect
Now that Razorpay is set up, it’s time to add the registrant to Zoom through Pabbly Connect. Select Zoom as the action application. Choose the action event as ‘Add Registrant’. This action will allow you to add participants to your workshop automatically.
Fill in the required fields such as the registrant’s name and email, which you obtained from the Razorpay trigger. Make sure to test this action to confirm that the registrant is added successfully to your Zoom workshop. This step ensures that your integration is working as intended.
Finalizing the Integration in Pabbly Connect
After testing both the Razorpay trigger and the Zoom action, you will finalize your integration in Pabbly Connect. Ensure all settings are correct and save your workflow. This step is essential to activate the automation process.
Now, every time a payment is received through Razorpay, the registrant will be automatically added to your Zoom workshop. This integration streamlines your registration process, saving you time and effort.
Integrating Razorpay and Zoom using Pabbly Connect allows you to automate the addition of workshop registrants upon payment receipt. This setup enhances efficiency in managing registrations seamlessly.
