Learn how to send automated WhatsApp messages to Facebook leads for your telecom equipment business using Pabbly Connect. Follow our step-by-step guide for seamless integration.
To send automated WhatsApp messages to Facebook leads for your telecom equipment business, you first need to access Pabbly Connect. Start by signing in to your existing account or create a new one if you’re a first-time user. Pabbly Connect offers 100 free tasks per month, making it easy to get started.
Once logged in, navigate to the dashboard and click on the Pabbly Connect option. This will lead you to the interface where you can create workflows that connect your applications.
After accessing Pabbly Connect, you can create a new workflow to automate your WhatsApp messaging process. Click on the Create Workflow button in the top right corner. In the dialog box that appears, name your workflow, such as ‘Send Automated WhatsApp Message to Facebook Leads’.
- Select a folder to save your workflow, like ‘Facebook Lead Ads’.
- Click on the Create button to proceed.
This step sets up the basic structure for your automation, allowing you to define triggers and actions that will execute when a new lead is generated.
3. Setting Up Trigger and Action for WhatsApp Messages
In your new workflow, the next step is to define the trigger and action. The trigger will be Facebook Lead Ads, and the action will be sending a WhatsApp message. Select Facebook as your trigger application and choose the trigger event as New Lead Instant.
For the action application, choose WhatsApp and set the action event to Send Template Message. This configuration ensures that every time a new lead is captured through Facebook, an automated WhatsApp message will be sent to that lead.
4. Connecting Facebook Lead Ads and WhatsApp via Pabbly Connect
To connect Facebook Lead Ads with Pabbly Connect, click on the Connect button in the trigger settings. You will need to authorize your Facebook account, which establishes a secure connection between the two platforms. Once connected, select the Facebook page and the lead generation form associated with your telecom equipment business.
- Choose your Facebook page, for example, ‘Connect Tech’.
- Select the lead gen form, such as ‘Telecommunication Lead Form’.
After setting this up, click on Save and Send Test Request to validate the integration. This will allow Pabbly Connect to capture lead information for subsequent WhatsApp messaging.
5. Sending Automated WhatsApp Messages to Facebook Leads
With your Facebook Lead Ads connected to Pabbly Connect, the next step is to configure the WhatsApp messaging. You need to connect your WhatsApp application, typically through WATI, by providing the API endpoint and access token from your WATI account.
Once the connection is established, map the phone number from the Facebook lead data to the WhatsApp message. Select the appropriate template you created in WATI, such as ‘Facebook Lead Ads’, and customize the message to include the lead’s name dynamically.
After configuring all details, click on Save and Send Test Request. If successful, you will see the WhatsApp message sent to the test lead, confirming that your integration using Pabbly Connect is working flawlessly.
In this tutorial, we demonstrated how to send automated WhatsApp messages to Facebook leads for your telecom equipment business using Pabbly Connect. By following these steps, you can streamline your communication process and enhance your lead engagement effectively.
