Learn how to send automated WhatsApp messages to your animal husbandry business using Pabbly Connect and Facebook Lead Ads. Step-by-step tutorial included. Discover hidden automation capabilities within your existing tools. This guide shows you how to connect your essential applications and permanently eliminate redundant manual processes.
To automate WhatsApp messages for your animal husbandry business, the first step is to set up Pabbly Connect. Begin by visiting the Pabbly Connect website and signing into your account. If you’re new, you can sign up for free and receive 100 free tasks every month, which is perfect for testing your automation.
Once logged in, navigate to the dashboard where you will find several applications. Click on the ‘Access Now’ button under Pabbly Connect to start creating your workflow. This platform will facilitate the integration between Facebook Lead Ads and WhatsApp Cloud API.
The next step involves creating a workflow in Pabbly Connect. Click on the ‘Create Workflow’ button located at the top right corner of the dashboard. A dialog box will appear prompting you to name your workflow; name it something descriptive, such as ‘Livestock Junction Facebook Lead Ads to WhatsApp’.
- Select a specific folder for your workflow to keep it organized.
- After naming and selecting a folder, click on the ‘Create’ button.
After creating your workflow, you will see two sections: Trigger and Action. In this automation, the trigger is Facebook Lead Ads, which will initiate the process every time a new lead is generated.
3. Configuring Facebook Lead Ads as the Trigger
To configure Facebook Lead Ads as your trigger in Pabbly Connect, click on the arrow under the Trigger section. Select Facebook Lead Ads from the list of applications. Then, choose the trigger event as ‘New Lead Instant’. This event will capture new leads as they come in.
Next, click on ‘Connect’ to link your Facebook Lead Ads account with Pabbly Connect. If you have an existing connection, you can select that, or click on ‘Add New Connection’ to create a new one. Once authorized, select your business page, which is ‘Livestock Junction,’ and the lead generation form named ‘Animal Husbandry’.
4. Setting Up WhatsApp Cloud API as the Action
After successfully setting up the trigger, it’s time to configure WhatsApp Cloud API as the action step in Pabbly Connect. Click on the action arrow and select WhatsApp Cloud API. The action event you want to choose is ‘Send Template Message’.
Next, click on ‘Connect’ and add a new connection. You will need to provide the API token, phone number ID, and WhatsApp business account ID. These details are crucial for ensuring that WhatsApp can send messages on your behalf. Once entered, save your connection settings.
- Select the template name you created in WhatsApp Cloud API, such as ‘Livestock Junction’.
- Map the recipient’s mobile number from the trigger step so that it dynamically updates for each new lead.
After filling in all necessary details, click on ‘Save and Send Test Request’. This will send a test message to verify that everything is working correctly.
5. Testing the Integration and Sending Messages
Now that you have set up both the trigger and action in Pabbly Connect, it’s time to test the integration. Use the Facebook Lead Ads testing tool to submit a test lead. Fill in the form with dummy data and submit it. This will simulate a new lead being generated.
After submitting the test lead, go back to Pabbly Connect and check if the response has been captured. You should see the details of the test lead. If successful, you will receive a WhatsApp message at the number you provided, confirming the integration.
Repeat the process to ensure that everything works smoothly. Each time a new lead is generated via Facebook Lead Ads, Pabbly Connect will automatically send a WhatsApp message using the template you created, enhancing your customer engagement.
In conclusion, using Pabbly Connect to automate WhatsApp messages for your animal husbandry business is an efficient way to engage with new leads. By integrating Facebook Lead Ads and WhatsApp Cloud API, you can ensure timely communication with your customers. This setup not only saves time but also improves customer satisfaction.
