Learn how to automate WhatsApp messages to your modular kitchen business leads using Pabbly Connect, Facebook Lead Ads, and Vati integration. Eliminate manual repetitive tasks from your workflow. Discover proven automation methods with intuitive steps designed for efficiency-minded professionals.
Accessing Pabbly Connect for WhatsApp Automation
To automate WhatsApp messages for your modular kitchen business leads, start by accessing Pabbly Connect. This platform serves as the integration hub that connects Facebook Lead Ads with Vati, the WhatsApp API.
Begin by visiting the Pabbly website. If you don’t have an account, you can sign up for free, which gives you access to 100 tasks each month. Once signed in, click on the Access Now button under Pabbly Connect to navigate to your dashboard.
In your Pabbly Connect dashboard, you will need to create a new workflow for sending automated WhatsApp messages. Click on the Create Workflow button and name your workflow appropriately, such as ‘Send Automated WhatsApp Message to Modular Kitchen Leads’.
Next, select the folder where you want to save this workflow. After creating the workflow, you will see two boxes labeled Trigger and Action. The Trigger will be set to Facebook Lead Ads, while the Action will be set to Vati. This setup allows you to automate the process effectively.
Setting Trigger with Facebook Lead Ads in Pabbly Connect
To set up the trigger in Pabbly Connect, choose Facebook Lead Ads as your trigger application. You will then need to select the trigger event, which is New Lead Instant. This event activates whenever a new lead is generated.
After selecting the trigger event, connect your Facebook account by clicking on Add New Connection. Once connected, you will need to select your Facebook page and the lead generation form. In this case, the page is named ‘Kitchen Cuddles’ and the form is titled ‘Contact Form’.
- Select your Facebook Page: Kitchen Cuddles
- Select your Lead Form: Contact Form
- Click on Save and Send Test
Make sure your lead generation form is live to test this setup successfully.
Sending WhatsApp Message with Vati through Pabbly Connect
After setting up the trigger, the next step is to configure the action in Pabbly Connect. Choose Vati as the action application and select the action event as Send Template Message. This allows you to send a WhatsApp message to the lead captured from Facebook.
To connect Vati, you will need to provide the API endpoint and access token. These can be found in the Vati API documentation. Copy the API endpoint and access token, then paste them into the respective fields in Pabbly Connect.
- Paste API Endpoint from Vati
- Paste Access Token from Vati
- Map the WhatsApp number of the lead
Once all details are filled, click on Save and Test to ensure the message is sent correctly.
By following these steps, you can effectively use Pabbly Connect to automate WhatsApp messages to your modular kitchen business leads. This integration streamlines communication and enhances customer engagement, allowing you to focus on growing your business.
