Learn how to automate WhatsApp messages for Indiamart inquiries using Pabbly Connect. Follow this step-by-step tutorial for seamless integration. Transform complex automation concepts into accessible, actionable steps that eliminate unnecessary manual work while maximizing existing application capabilities.
To automate WhatsApp messages using Pabbly Connect, first, access the Pabbly Connect website. Sign in to your account or create a new one to start your automation journey.
Once logged in, you will see the Pabbly Connect dashboard. From here, you can easily create workflows that connect various applications, including Indiamart and WhatsApp.
In this section, we will create a new workflow in Pabbly Connect to send WhatsApp messages for Indiamart inquiries. Click on the ‘Create Workflow’ button located at the top right corner of the dashboard.
- Enter a name for your workflow, such as ‘Send Automated WhatsApp Messages for Indiamart Inquiries’.
- Select a folder where you want to save this workflow.
- Click on the ‘Create’ button to finalize your workflow setup.
After creating the workflow, you will see two windows: Trigger and Action. The Trigger will initiate the workflow whenever a new lead is generated on Indiamart.
For the Trigger application, select ‘Indiamart’ in Pabbly Connect. Choose the trigger event as ‘New Lead’ to capture any new inquiries automatically.
After setting up the trigger, Pabbly Connect will provide you with a webhook URL. Copy this URL to connect with Indiamart.
- Log in to your Indiamart account and navigate to the Lead Manager.
- Select the ‘Push API’ option under Import/Export Leads.
- Paste the copied webhook URL from Pabbly Connect and save the details.
By following these steps, you will successfully set up the trigger to automatically capture new leads generated in Indiamart.
Next, we need to set up the Action step in Pabbly Connect. For the Action application, select ‘WhatsApp by AI Sensi’ and choose the action event as ‘Send Template Message’.
Now, connect your WhatsApp account by entering the API key. To get the API key, navigate to your WhatsApp by AI Sensi account and find the API key under the manage section.
Create a campaign in your WhatsApp by AI Sensi account and ensure its status is live. Map the mobile number and customer name fields from the previous step to personalize the message. Click on ‘Save and Send Test Request’ to send a test message.
This step ensures that whenever a new lead is captured, a personalized WhatsApp message will be sent automatically.
5. Conclusion: Automating WhatsApp Messages with Pabbly Connect
In this tutorial, we successfully integrated Indiamart with WhatsApp using Pabbly Connect. This automation allows you to send immediate WhatsApp messages to new leads, enhancing customer engagement and saving time.
By following these steps, you can streamline your communication process and ensure that your customers receive timely responses to their inquiries.
Automating WhatsApp messages for Indiamart inquiries using Pabbly Connect not only increases efficiency but also improves customer satisfaction. Start using Pabbly Connect today to enhance your business operations.
