Learn how to automate WhatsApp messages to your False Ceiling business leads using Pabbly Connect with Facebook integration. Follow our step-by-step tutorial. Transform complex automation concepts into accessible, actionable steps that eliminate unnecessary manual work while maximizing existing application capabilities.
1. Accessing Pabbly Connect for WhatsApp Automation
To automate WhatsApp messages for your False Ceiling business leads, you will first need to access Pabbly Connect. Start by visiting the Pabbly website and either sign in or create a free account in just two minutes. This platform is essential for integrating various applications, including Facebook Lead Ads and WhatsApp.
Once logged in, navigate to the dashboard of Pabbly Connect. Here, you can create a new workflow by clicking on the ‘Create Workflow’ button. This will allow you to set up the automation process that connects your Facebook leads with WhatsApp messaging.
In this section, we will create a workflow specifically for sending automated WhatsApp messages to your leads. After clicking on ‘Create Workflow’, name it according to your objective, such as ‘Send Automated WhatsApp Message to False Ceiling Business Lead’. Choose the appropriate folder to save your workflow.
- Select the Trigger application as Facebook Lead Ads.
- Set the Trigger event to ‘New Lead Instant’.
- Connect your Facebook account to Pabbly Connect.
After setting up the trigger, ensure to test the connection. This step is crucial as it allows Pabbly Connect to receive new lead data from Facebook Lead Ads, which will trigger the WhatsApp message automation.
3. Mapping Facebook Lead Details in Pabbly Connect
Now that the trigger is set, it’s time to map the lead details from Facebook to Pabbly Connect. You will need to select your Facebook page and the lead generation form that you are using. For this example, the page is named ‘Cloud9 Ceilings’ and the lead form is titled ‘New Form’.
Ensure that your lead generation form is live before making a sample submission. This is necessary to test the integration. You can do this by filling out the form with dummy details, which will generate a lead that Pabbly Connect can capture and use for sending messages.
- Select the necessary details like full name, email, and phone number.
- Click on ‘Save and Send Test Request’ to capture the lead details.
Once you have completed these steps, Pabbly Connect will hold the lead data, ready to be used in the WhatsApp messaging action.
4. Setting Up WhatsApp Integration in Pabbly Connect
Next, we will set up the WhatsApp messaging action using Pabbly Connect. For the action application, select ‘WT’ and choose the action event as ‘Send Template Message’. This will allow you to send customized messages to your leads.
To connect WT with Pabbly Connect, you will need to provide the API endpoint and access token. These details can be found in the API documentation of WT. Once you have pasted these into Pabbly Connect, click on ‘Save’ to establish the connection.
Map the WhatsApp number from the Facebook lead response. Select the message template you created in WT. Fill in any required parameters for the message.
After filling in these details, click on ‘Save and Send Test Request’. If everything is set up correctly, you should receive a confirmation that the automated WhatsApp message has been sent successfully.
5. Conclusion: Automating WhatsApp Messages with Pabbly Connect
In conclusion, using Pabbly Connect to automate WhatsApp messages for your False Ceiling business leads is a straightforward process. By following the steps outlined above, you can ensure that every new lead from Facebook gets an immediate, personalized message.
Integrating Facebook Lead Ads with WhatsApp through Pabbly Connect not only saves time but also enhances customer engagement. Start using Pabbly Connect today to streamline your communications and grow your business effectively.
