Learn how to send automated WhatsApp messages to Facebook leads for your telecom equipment business using Pabbly Connect. Follow our step-by-step guide for seamless integration.
Accessing Pabbly Connect for Your Telecom Equipment Business
To start sending automated WhatsApp messages to Facebook leads, the first step is to access Pabbly Connect. As a user, you can sign in or create an account if you’re new. Pabbly Connect allows you to automate workflows easily, making it ideal for your telecom equipment business.
Once logged in, navigate to the dashboard to create a workflow. Click on the ‘Create Workflow’ button, where you can name your workflow, such as ‘Send Automated WhatsApp Message to Facebook Leads’. This setup is critical for integrating WhatsApp with Facebook leads through Pabbly Connect.
Setting Up Trigger and Action in Pabbly Connect
In this section, you will set up the trigger and action for your workflow using Pabbly Connect. The trigger will be Facebook Lead Ads, and the action will be sending a WhatsApp message. Select ‘Facebook Lead Ads’ as your trigger application and choose ‘New Lead Instant’ as the trigger event.
- Select ‘Facebook Lead Ads’ as the trigger application.
- Choose ‘New Lead Instant’ as the trigger event.
- Click on ‘Connect’ to establish a connection with Facebook.
After connecting, you need to select your Facebook page and the associated lead generation form. This step is crucial for ensuring that Pabbly Connect captures leads accurately from your Facebook ads, making the integration seamless.
Testing the Integration with Pabbly Connect
Once your trigger is set, it’s time to test the integration. In Pabbly Connect, after saving your settings, you will need to create a test lead using the Meta for Developers tool. This step verifies that your integration is correctly set up to receive data from Facebook.
To create a test lead, go to the Meta for Developers page and use the Lead Ads Testing Tool. Select your Facebook page and the lead form, fill in the necessary details, and submit the form. This action will trigger Pabbly Connect to capture the lead data.
- Go to Meta for Developers and access your apps.
- Use the Lead Ads Testing Tool to create a test lead.
- Submit the lead form to check if Pabbly Connect captures the data.
After submitting, you should see the test lead details appear in your Pabbly Connect dashboard, confirming a successful trigger setup.
Sending WhatsApp Messages Using Pabbly Connect
Now that you have successfully tested the integration, the next step is to configure the action to send WhatsApp messages to your leads. In Pabbly Connect, select ‘Wati’ as your action application and choose ‘Send Template Message’ as the action event.
To set this up, you will need to connect your Wati account to Pabbly Connect. Enter the API endpoint and access token from your Wati account. This connection allows Pabbly Connect to send messages directly to your leads’ WhatsApp numbers.
Select ‘Wati’ as the action application. Choose ‘Send Template Message’ as the action event. Map the WhatsApp number and template details.
Fill in the required fields, such as the WhatsApp number, template name, and custom parameters. Once everything is mapped correctly, save the settings and send a test request. This will confirm that your automated WhatsApp message is sent successfully to the new lead.
In summary, using Pabbly Connect to send automated WhatsApp messages to Facebook leads for your telecom equipment business streamlines your communication process. By following these steps, you can efficiently integrate WhatsApp with Facebook leads, ensuring timely responses to potential customers.
