Learn how to automate your Telegram bot using Pabbly Connect with Google Gemini. Follow this detailed tutorial for seamless integration. Explore efficient methods for automating routine tasks with clear, concise instructions suited for both newcomers and experienced professionals.
To automate your Telegram bot using Pabbly Connect, start by visiting the Pabbly Connect website. If you are a new user, you can sign up for a free account to get started with 100 free tasks every month. Existing users should simply sign in to their accounts.
Once logged in, you will see the dashboard displaying various Pabbly applications. Click on ‘Access Now’ under Pabbly Connect to proceed. This will open the Pabbly Connect dashboard where you can create a new workflow for your automation.
In order to create an automation between your Telegram bot and Google Gemini, you need to set up a workflow in Pabbly Connect. Click on the ‘Create Workflow’ button located at the top right corner of the dashboard. A dialog box will prompt you to name your workflow.
  • Name your workflow as ‘Automate Telegram Bot Using Pabbly Connect’.
  • Select a folder to save your workflow, such as ‘Telegram Bot Automations’.
  • Click on the ‘Create’ button to finalize the workflow setup.
After creating the workflow, you will see two sections: Trigger and Action. The trigger is what initiates the automation, and the action is the response that occurs as a result. This is where Pabbly Connect truly facilitates the integration process.
3. Setting Up the Trigger for Telegram Bot
The next step involves setting up the trigger in Pabbly Connect. Click on the trigger application dropdown and select ‘Telegram Bot’. For the trigger event, choose ‘Set Webhook Slash Updates’ to capture incoming messages from your Telegram group.
To connect your Telegram bot, you first need to create a bot using the BotFather on Telegram. Once your bot is created, copy the token provided by BotFather and paste it into Pabbly Connect. This connection allows your bot to communicate with the Pabbly platform.
  • Search for ‘BotFather’ in your Telegram app.
  • Click on ‘Start’ to initiate the BotFather chat.
  • Create a new bot by selecting ‘New Bot’ and following the prompts.
After setting up the trigger, you can test it by sending a message in your Telegram group to ensure that Pabbly Connect captures the response correctly.
4. Setting Up the Action Step with Google Gemini
Once the trigger is established, the next step is to set up the action using Google Gemini in Pabbly Connect. Click on the plus icon to add a new action step and select ‘Google Generative AI’ as the action application.
For the action event, select ‘Generate Content’. You will need to connect your Google Gemini account by providing the API key. This key can be obtained from the Google AI Studio.
Click on the hyperlink to access Google AI Studio. Create a new API key under the ‘Get API Key’ section. Copy the generated API key and paste it into Pabbly Connect.
After entering the API key, set up the prompt for the content generation. You can map the data from the previous step to ensure that the response is dynamic and relevant to the questions asked in your Telegram group.
5. Sending Replies Back to Telegram Group
The final step involves sending the generated response back to your Telegram group. In Pabbly Connect, add another action step and select ‘Telegram Bot’ again for the action application. This time, choose the action event ‘Send a Text Message’.
Map the chat ID and the response content from the previous steps to ensure that the bot replies in the group. Once you click on ‘Save and Send Test Request’, you should see the reply appear in your Telegram group, confirming that the automation is working correctly.
Ensure the bot has admin privileges in the group to send messages. Test the complete workflow by asking a question in the group. Check if the bot responds automatically with the generated reply.
This entire process showcases how Pabbly Connect seamlessly integrates Google Gemini and Telegram Bot to automate responses, making your communication more efficient.
In this tutorial, we explored how to automate a Telegram bot using Pabbly Connect with Google Gemini. By following the specific steps outlined, you can create an efficient workflow that automatically responds to questions in your Telegram group, enhancing team collaboration.
