Learn how to integrate Stripe payments with Flowdesk subscribers using Pabbly Connect for seamless automation. Follow our detailed step-by-step guide. Navigate the automation landscape confidently with clear, structured guidance suitable for professionals regardless of prior technical experience.
To begin automating your workflow, access Pabbly Connect. This platform enables seamless integration between Stripe and Flowdesk. First, create a free account on Pabbly Connect, which can be done in just two minutes.
Once logged into your Pabbly Connect dashboard, click on the blue ‘Create Workflow’ button. Name your workflow, such as ‘Create Subscriber in Flowdesk on Stripe Payment,’ and click on the ‘Create’ button to proceed.
In this step, you will set up the trigger for your integration using Pabbly Connect. The trigger is activated when a new payment is made in Stripe. Select the Stripe application and choose ‘New Charge’ as the trigger event.
  • Select Stripe as the application.
  • Choose ‘New Charge’ as the event.
Next, navigate to your Stripe dashboard and go to the Developer section. Click on ‘Webhooks’ and then ‘Add Endpoint.’ Paste the webhook URL you copied earlier, and select the event ‘Charge Succeeded.’ Save the endpoint to complete this part of the setup.
3. Making a Dummy Payment to Test the Connection
Now, to test the connection between Stripe and Pabbly Connect, you need to make a dummy payment. Open the payment link for a product in Stripe and enter the required details, such as email and card information.
Once the payment is successful, Pabbly Connect will receive the payment details through the webhook. Check the response in Pabbly Connect to ensure it captured the necessary customer information, including name and email.
This step confirms that the integration is working correctly. You should see the details populated in the Pabbly Connect interface, allowing you to proceed with creating a subscriber in Flowdesk.
4. Creating a Subscriber in Flowdesk
With the payment details captured, it’s time to create a subscriber in Flowdesk using Pabbly Connect. Select Flowdesk as the action application and choose ‘Create or Update Subscriber’ as the action event.
  • Connect to Flowdesk using your credentials.
  • Map the email field to the email captured from the Stripe payment.
  • Use the text formatter in Pabbly Connect to split the full name into first and last names if necessary.
After mapping the required fields, click on ‘Save and Send Test Request’ to create the subscriber. Refresh your Flowdesk dashboard to verify that the subscriber has been successfully created.
5. Adding Subscriber to a Specific Segment
Lastly, you can enhance your workflow by adding the newly created subscriber to a specific segment in Flowdesk using Pabbly Connect. Select Flowdesk again and choose ‘Add Existing Subscriber to Segment’ as the action event.
Map the subscriber’s email to the corresponding field and select the segment where you want to add the subscriber. Create a new segment if necessary, such as ‘All Stripe Customers,’ to keep your subscribers organized.
Click on ‘Save and Send Test Request’ to finalize this step. Once you refresh your Flowdesk account, you should see the subscriber added to the specified segment, completing the automation process.
By using Pabbly Connect, you can efficiently automate the process of integrating Stripe payments with Flowdesk subscribers. This integration allows you to manage your subscribers seamlessly without manual intervention, streamlining your email marketing efforts.
