Learn how to automatically share WooCommerce products on Facebook using Pabbly Connect. Step-by-step tutorial with detailed instructions. Navigate the automation landscape confidently with clear, structured guidance suitable for professionals regardless of prior technical experience.
1. Setting Up Pabbly Connect for WooCommerce and Facebook Integration
Pabbly Connect is essential for automating the process of sharing WooCommerce products on Facebook. To begin, log into your Pabbly Connect account. If you don’t have an account, you can create one quickly and start using the free tasks available. using Pabbly Connect
Once logged in, navigate to the dashboard and click on the blue button labeled ‘Create Workflow’. Assign a name to your workflow, such as ‘Share WooCommerce Products on Facebook Page Automatically’. Select the folder where you want to save this workflow and click on ‘Create’.
2. Configuring WooCommerce as the Trigger Application in Pabbly Connect
In this step, you will configure WooCommerce as the trigger application in Pabbly Connect. Select WooCommerce from the list of applications and set the trigger event to ‘New Product Created’. This means that every time a new product is added to your WooCommerce store, it will trigger an action in Pabbly Connect.
- Select WooCommerce as the trigger application.
- Choose the event ‘New Product Created’.
Next, go to your WooCommerce settings, navigate to the ‘Advanced’ section, and select ‘Webhooks’. Create a new webhook by pasting the copied URL into the delivery URL field. Name the webhook and set its status to active, then select the topic as ‘Product Created’ and save the webhook.
3. Testing the WooCommerce Trigger in Pabbly Connect
After saving the webhook, return to Pabbly Connect. Here, you will see a response indicating that the webhook has been successfully added. To test this integration, you need to create a new product in your WooCommerce store.
- Navigate to the Products section in WooCommerce.
- Add a new product with details like name, price, and description.
- Publish the product to trigger the webhook.
Once the product is published, return to Pabbly Connect and click on ‘Recapture Webhook Response’. This action will allow Pabbly Connect to capture the details of the newly created product, confirming that the integration is working correctly.
4. Setting Up Facebook as the Action Application in Pabbly Connect
With the WooCommerce trigger successfully set up, the next step is to configure Facebook as the action application in Pabbly Connect. Select Facebook and choose the action event ‘Create Page Photo Post’. This step allows you to share the product image along with its details on your Facebook page.
Click on ‘Connect’, and since you are already logged into Facebook, grant the necessary permissions. Once connected, choose the specific Facebook page where you want to share the products. You will then need to map the product details captured from WooCommerce to the fields in Facebook.
Map the product image URL from the WooCommerce response. Add a description that includes the product name, price, and a link to the product. Ensure all details are formatted correctly for a professional post.
After mapping all the necessary fields, click on the button to send the request. Pabbly Connect will then post the product details automatically to your Facebook page.
5. Verifying the Successful Integration of WooCommerce and Facebook via Pabbly Connect
To verify that the integration is successful, refresh your Facebook page after sending the request. You should see the new product shared automatically, complete with the product image, description, and link. This demonstrates that Pabbly Connect is functioning as intended, automating the sharing process seamlessly.
If the post appears correctly, it confirms that every time a new product is added to WooCommerce, it will automatically be shared on Facebook without any manual effort. This automation saves time and enhances your marketing efforts.
With Pabbly Connect, you can automate many tasks across various applications, ensuring your business runs smoothly without manual intervention. This integration not only improves efficiency but also helps in maintaining a consistent online presence.
Using Pabbly Connect, you can easily automate the process of sharing WooCommerce products on Facebook. This integration saves time and ensures your products reach a wider audience automatically.
