Learn how to automate product feedback from Typeform to Airtable and Trello using Pabbly Connect in this detailed tutorial. Navigate the automation landscape confidently with clear, structured guidance suitable for professionals regardless of prior technical experience.
1. Introduction to Pabbly Connect for Automation
Pabbly Connect is an essential tool for automating product feedback. This platform allows seamless integration of various applications, such as Typeform, Airtable, and Trello. In this tutorial, we will set up an automation workflow using Pabbly Connect to collect feedback from Typeform and send it to Airtable and Trello.
To get started, you need to create an account on Pabbly Connect. Once logged in, you can access the dashboard where you will set up your automation workflow. The first step is to create a new workflow that will connect Typeform to Airtable and Trello through Pabbly Connect.
2. Setting Up Typeform in Pabbly Connect
To begin, you need to set up Typeform to collect feedback from users. In Pabbly Connect, select Typeform as the trigger application. This will allow the workflow to initiate every time a new form submission is made.
  • Choose the Typeform trigger event as ‘New Entry’
  • Connect your Typeform account to Pabbly Connect
  • Select the specific Typeform you want to use for feedback collection
Once you have configured the Typeform settings, test the trigger to ensure it captures the data correctly. This integration allows Pabbly Connect to listen for new entries in your Typeform, which will be essential for the next steps.
3. Sending Data to Airtable via Pabbly Connect
After successfully capturing data from Typeform, the next step is to send this data to Airtable. In the Pabbly Connect workflow, add Airtable as the action application. This step ensures that every feedback entry is logged in your Airtable database.
  • Select the Airtable action event as ‘Create Record’
  • Connect your Airtable account to Pabbly Connect
  • Map the fields from Typeform to the corresponding fields in Airtable
Make sure to test the Airtable integration to confirm that the feedback from Typeform is being correctly added as a new record in your Airtable base. This integration is vital for maintaining organized feedback data using Pabbly Connect.
4. Creating a Card in Trello Using Pabbly Connect
The final step in this automation process is to create a card in Trello for each new feedback entry. In your Pabbly Connect workflow, add Trello as another action application. This allows you to keep track of feedback in a project management tool.
Choose the Trello action event as ‘Create Card’ Connect your Trello account to Pabbly Connect Select the board and list where you want to create the card Map the feedback fields to the card details
Once you have set up the Trello integration, test it to ensure that a card is created for each new feedback submission from Typeform. This step completes the automation process, showcasing the power of Pabbly Connect in streamlining your workflow.
5. Conclusion
In this tutorial, we demonstrated how to automate product feedback from Typeform to Airtable and create a card in Trello using Pabbly Connect. By following these steps, you can efficiently manage feedback and enhance your workflow.
Utilizing Pabbly Connect for integration ensures that your processes are streamlined, saving you time and effort in managing product feedback effectively.
