Learn how to automate MailerLite subscriber creation using Pabbly Connect with Vado TV leads in this detailed tutorial. Step-by-step instructions included! Discover how to seamlessly connect your essential tools through accessible instructions that make powerful automation available to professionals at every skill level.
To begin the integration process, you need to access Pabbly Connect. Start by opening your browser and navigating to Pabbly.com/connect. If you’re a new user, click on the ‘Sign Up for Free’ option to create your account. Existing users can simply sign in.
Once logged in, you will be directed to the dashboard where you can see all your workflows. To create a new workflow, click on the ‘Create Workflow’ button in the top right corner. A dialog box will appear, prompting you to name your workflow. Name it ‘Create MailerLite Subscribers from Vado TV Leads’ and click on ‘Create’.
2. Setting Up the Trigger with Vado TV
In this step, we will set up the trigger in Pabbly Connect using Vado TV. Select Vado TV as your trigger application and choose the trigger event as ‘Lead Captured’. After selecting the trigger event, you will receive a webhook URL that needs to be configured in your Vado TV account.
  • Open your Vado TV account and navigate to the project settings.
  • Select ‘Integrations’ and then click on ‘Add Webhook’.
  • Paste the provided webhook URL and select ‘Lead Capture’ as your notification type.
  • Save the changes to set up the webhook.
After saving the webhook, return to Pabbly Connect and click on ‘Test Webhook’. This will allow you to capture the lead data when a lead is generated in Vado TV.
3. Customizing Lead Capture in Vado TV
Next, we will customize the lead capture form in Vado TV. Navigate to the marketing section of your project and enable the lead capture feature. You can customize the fields in your form, which typically includes name, email, and phone number. using Pabbly Connect
  • Turn on the lead capture option.
  • Select the fields you want to include in the form.
  • Set the display time for the form to appear, for example, 2 seconds.
After making these customizations, click on ‘Save Changes’. This ensures that whenever a video is played, the lead capture form will appear and allow viewers to submit their information.
4. Setting Up Action to Create Subscribers in MailerLite
Now, let’s configure the action step in Pabbly Connect to create subscribers in MailerLite. Select MailerLite as your action application and choose the action event as ‘Add or Update Subscriber in Group’. Click on ‘Connect’ and choose to add a new connection by entering your MailerLite API key, which you can find in the Integrations section of your MailerLite account.
Navigate to your MailerLite account settings. Under your profile picture, go to ‘Integrations’. Copy the API key and paste it into Pabbly Connect.
Once connected, you will need to specify the group ID where the new subscribers will be added. Select the group you created in MailerLite for new leads and map the lead details from the previous step to ensure the subscriber information is correctly added.
Finally, it’s time to test the integration workflow in Pabbly Connect. After setting up the action, click on ‘Save and Send Test Request’. This will send the captured lead data from Vado TV to MailerLite, creating a new subscriber.
Check your MailerLite account to confirm that the new subscriber has been added successfully. You should also receive a confirmation email at the address provided during the lead capture. This confirms that the integration is working as expected and that every new lead captured in Vado TV results in a new subscriber in MailerLite.
This tutorial demonstrated how to automate the creation of MailerLite subscribers using Pabbly Connect with leads captured from Vado TV. By following these steps, you can seamlessly integrate various applications to enhance your marketing automation.
