Learn how to automate Mailer Light using Pabbly Connect in this detailed tutorial. Streamline your email marketing with seamless integrations and no coding required. Learn to create powerful connections between your critical applications without requiring specialized programming knowledge or extensive technical background.
1. Accessing Pabbly Connect for Mailer Light Integration
To automate Mailer Light using Pabbly Connect, start by accessing the platform. Go to the URL Pabbly.com/connect in your browser. You will see options to sign in or sign up for free.
If you’re a new user, click on ‘Sign Up for Free’ to create an account. After signing up, you’ll receive 100 free tasks every month to explore Pabbly Connect. Existing users should click on ‘Sign In’ to log into their accounts.
Once logged in, navigate to the dashboard of Pabbly Connect. Here, you can create a new workflow by clicking on the ‘Create Workflow’ option. A dialog box will prompt you to name your workflow.
For this integration, name your workflow ‘Automate Mailer Light’ and select a folder to save it in. After selecting the folder, click on ‘Create’. You will be presented with two windows: Trigger and Action.
  • Select Mailer Light as the Trigger application.
  • Choose the trigger event, for example, ‘Subscriber Added’.
  • Click on ‘Connect’ to build the connection.
After setting up the trigger, you can proceed to configure the action step in your workflow.
3. Setting Up Mailer Light as a Trigger
In the Trigger section of Pabbly Connect, select Mailer Light as the application. Choose the trigger event, such as ‘Subscriber Removed from Group’. Click on ‘Connect’ to establish the connection.
You will need to provide the API key from your Mailer Light account. To get the API key, navigate to the Integrations section in Mailer Light, and generate a new API token. Copy this token and paste it into the Pabbly Connect connection field.
  • Generate a new API token in Mailer Light under the Integrations section.
  • Paste the API token into Pabbly Connect.
  • Click on ‘Save’ to finalize the connection.
After saving, click on ‘Save and Send Test Request’ to ensure that the connection is successful. You will receive a response confirming the setup.
4. Adding Action Steps with Pabbly Connect
After successfully setting up Mailer Light as a trigger, you can now add action steps. For instance, you can send new subscriber details to Google Sheets or notify your team on Google Chat. using Pabbly Connect
To add Google Sheets, select it as the action application. Choose the action event, such as ‘Create New Row’. Connect Google Sheets using the same API key method as before, ensuring you have the correct permissions set.
Select Google Sheets as the action application. Choose the action event like ‘Create New Row’. Map the necessary fields from Mailer Light to Google Sheets.
Once the action is configured, you can test the entire workflow. When a subscriber is removed from Mailer Light, their details will automatically be sent to Google Sheets.
5. Conclusion: Automating Mailer Light with Pabbly Connect
In this tutorial, we explored how to automate Mailer Light using Pabbly Connect. You learned how to set up triggers and actions efficiently without any coding skills. This automation can significantly streamline your email marketing efforts.
By integrating Mailer Light with other applications like Google Sheets and Google Chat through Pabbly Connect, you can enhance productivity and maintain accurate records. Start automating your email marketing today for better engagement and efficiency!
