Learn how to automate adding Instagram lead ads leads to Kit subscribers using Pabbly Connect with this step-by-step tutorial. Discover how to seamlessly connect your essential tools through accessible instructions that make powerful automation available to professionals at every skill level.
1. Setting Up Pabbly Connect for Instagram Lead Ads
To automate the process of adding Instagram lead ads leads to Kit subscribers, we first need to set up Pabbly Connect. Begin by creating a free account on Pabbly Connect. You can find the sign-up link in the description box below. After signing up, log into your dashboard.
Once logged in, click on the ‘Create Workflow’ button and name your workflow, for example, ‘Instagram Lead Ads to Kit’. Choose the appropriate folder in your Pabbly Connect account to store this automation and then click on ‘Create’. This will open the workflow interface where you can set up your trigger and action steps.
2. Connecting Instagram Lead Ads with Pabbly Connect
In this step, we will connect our Instagram Lead Ads account with Pabbly Connect. In the trigger window, search for ‘Instagram Lead Ads’ and select it. Choose the trigger event as ‘New Lead Instant’. Click on ‘Connect’ and then select ‘Add New Connection’ to link your Instagram account.
- Ensure your Instagram account is connected to your Facebook account.
- Select the specific Facebook page you are using for your ads.
- Choose the lead gen form from which you want to capture leads.
After ensuring these connections, click on the ‘Connect with Instagram Lead’ button. Once connected, you will see a prompt asking for the Facebook page and lead gen form. Select the appropriate options and click on ‘Save and Send Test Request’ to confirm the setup.
3. Capturing Lead Details from Instagram
After setting up the trigger, Pabbly Connect will wait for new leads from your Instagram ads. You can either wait for a live lead or use Meta’s lead testing tool to generate a test lead. If using the testing tool, select your Facebook page and the lead gen form, then fill in the details of a test lead.
Once you submit the test lead, return to Pabbly Connect where you will see the lead details captured in the workflow. This confirms that the connection is successful and the automation is ready to process leads.
- Ensure the name, email, phone number, and gender fields are correctly filled out.
- Check that the details appear correctly in the Pabbly Connect response.
This step verifies that Pabbly Connect is effectively capturing leads from Instagram Lead Ads.
4. Adding Subscribers to Kit from Pabbly Connect
The next step involves sending the captured lead details to Kit as a subscriber. In the action window of Pabbly Connect, search for ‘Kit’ and select it. Choose the action event as ‘Add Subscriber to Sequence’. Click on ‘Connect’ and add a new connection using the API key and API secret from your Kit account.
To obtain these credentials, navigate to your Kit account settings and find the API key and secret under the developer section. Enter these in Pabbly Connect and click on ‘Save’. After establishing the connection, select the sequence ID where you want to add the new subscriber.
Map the email and first name fields from the trigger response to the Kit action step. Select any tags you wish to assign to the subscriber.
Finally, click on ‘Save and Send Test Request’ to confirm that the subscriber has been added successfully.
To ensure the automation is functioning correctly, we will test the workflow by generating another test lead through the Meta lead testing tool. First, delete the previous test lead to avoid conflicts. Select the Facebook page and lead gen form again, fill in the details for a new test lead, and submit.
Once submitted, return to your Kit account and check the subscribers section. You should see the new lead listed as a subscriber with the correct details. This confirms that the automation set up in Pabbly Connect is working flawlessly.
With this setup, you can efficiently manage leads from Instagram directly into your Kit account, leveraging the power of Pabbly Connect for seamless automation.
This tutorial demonstrated how to automate the process of adding Instagram lead ads leads to Kit subscribers using Pabbly Connect. By following these steps, you can streamline your lead management efficiently.
