Learn how to automate follow-up emails using Pabbly Connect and OpenAI. This step-by-step tutorial covers integration with Gmail and more. Eliminate manual repetitive tasks from your workflow. Discover proven automation methods with intuitive steps designed for efficiency-minded professionals.
1. Accessing Pabbly Connect for Email Automation
To automate follow-up emails using Pabbly Connect, start by accessing the platform. Pabbly Connect is essential for integrating Gmail and OpenAI seamlessly. If you’re new, you can sign up for a free account, which provides 100 free tasks each month. using Pabbly Connect
Once signed in, navigate to the dashboard where you can find all your workflows. To begin creating a new workflow, click on the ‘Create Workflow’ button. This will allow you to set up the automation process for sending follow-up emails based on feedback received.
2. Creating the Workflow in Pabbly Connect
In this section, we will create the workflow that automates the follow-up email process. Start by naming your workflow, such as ‘Send Follow-Up Emails for Positive Replies Using OpenAI.’ Next, select the folder where you want to save this workflow. using Pabbly Connect
  • Choose ‘Email Parser’ as your trigger application.
  • Set up the action to use OpenAI for content evaluation.
Following these steps will set the foundation for your automation. By using Pabbly Connect, you ensure that the entire process runs smoothly without manual intervention.
3. Setting Up Email Parser in Gmail
To capture emails, configure the Email Parser feature within Pabbly Connect. This involves copying the provided email hook and adding it to your Gmail settings. Pabbly Connect will then forward all new emails to this hook. using Pabbly Connect
In Gmail, go to ‘Settings’ and select ‘See All Settings.’ Under the ‘Forwarding and POP/IMAP’ tab, add the email hook as a forwarding address. Confirm the forwarding by clicking on the link sent to the hook email. Once confirmed, enable forwarding to allow Pabbly Connect to capture incoming emails.
4. Filtering for Positive Feedback with OpenAI
Once the emails are captured, the next step is to filter them for positive feedback. Use Pabbly Connect to set a condition that checks if the email subject contains the word ‘feedback.’ This ensures that only relevant emails trigger the follow-up process. using Pabbly Connect
  • Select ‘Filter’ as the action application.
  • Map the subject line from the email response.
  • Set the filter condition to check for the word ‘feedback.’
This filtering process is crucial as it prevents irrelevant emails from triggering follow-ups. Thus, Pabbly Connect allows for a more targeted email automation experience.
5. Sending Thank You Emails Using Gmail
After confirming that the feedback is positive, the last step is to send a thank you email. Choose Gmail as the action application in Pabbly Connect. Map the recipient’s email address from the parsed email response. using Pabbly Connect
For the email content, you can manually type a message or use OpenAI to generate a thank you email. Set the subject line as ‘Thank You for Your Positive Feedback’ and customize the email body to express gratitude. Finally, click ‘Save and Send Test Request’ to ensure the email is sent successfully.
In this tutorial, we have explored how to automate follow-up emails using Pabbly Connect and OpenAI. This integration streamlines the process of thanking customers for their positive feedback, enhancing customer engagement without manual effort.
