Learn how to automate sharing Blogger posts on Medium using Pabbly Connect, ensuring seamless integration of your content across platforms. Navigate the automation landscape confidently with clear, structured guidance suitable for professionals regardless of prior technical experience.
To start automating your Blogger posts to Medium, first access Pabbly Connect. Sign in to your existing account or create a new one for free. After logging in, you will see the Pabbly Connect dashboard.
Once you’re on the dashboard, locate the option to create a new workflow. This is crucial for setting up your automation process. Follow these simple steps to get started:
- Go to the Pabbly Connect website and log in.
After naming your workflow, you will be ready to set up the trigger and action steps necessary for the automation.
In this section, you will configure the trigger to monitor your Blogger account for new posts. Select Google Blogger as your trigger application within Pabbly Connect. The trigger event should be set to ‘New Post Added’ to ensure that whenever you publish a new post, it is captured automatically.
Here’s how to set up the trigger step:
- Choose ‘Blogger’ as the trigger application.
- Select ‘New Post Added’ as the trigger event.
- Connect your Google Blogger account.
After connecting, select the blog you want to monitor. Ensure to set the status to ‘Only Live’ so that only published posts are captured. This setup allows Pabbly Connect to trigger the action whenever a new post is published.
3. Creating a Post on Medium via Pabbly Connect
Now that the trigger is set, it’s time to configure the action step to create a post on Medium. Select Medium as the action application in Pabbly Connect. The action event will be ‘Create a Post’ which allows you to publish the captured content from Blogger directly to Medium.
To set up the action step, follow these steps:
Choose ‘Medium’ as the action application. Select ‘Create a Post’ as the action event. Connect your Medium account using the generated token.
After connecting, map the data from your Blogger post to the corresponding fields in Medium. This ensures that the title and content from Blogger are correctly transferred to Medium. Once everything is mapped, click on ‘Save and Send Test Request’ to finalize the action.
4. Testing and Verifying the Automation
After setting up both the trigger and action steps, it’s crucial to test the automation. Publish a new post on your Blogger account and monitor Pabbly Connect for the response. Ensure that the post appears on your Medium account as intended.
Here’s how to verify the automation:
Create a new post in Blogger with a unique title. Check for the response in Pabbly Connect. Log into Medium to confirm the new post is published.
If everything is set up correctly, your new Blogger post should automatically appear on Medium, showcasing the power of Pabbly Connect to streamline your content sharing process.
5. Conclusion
In this tutorial, we explored how to automate the process of sharing Blogger posts on Medium using Pabbly Connect. This integration not only saves time but also ensures your content reaches a wider audience seamlessly.
By following the steps outlined, you can easily set up this automation and enhance your blogging experience. With Pabbly Connect, connecting different applications becomes a straightforward task, allowing you to focus on creating great content.
