Learn how to autogenerate articles using Pabbly Connect with Google Sheets and Open Router. Follow this detailed tutorial for seamless integration. Eliminate manual repetitive tasks from your workflow. Discover proven automation methods with intuitive steps designed for efficiency-minded professionals.
To start using Pabbly Connect, first, visit the Pabbly website. If you don’t have an account, you can sign up for free, which only takes a couple of minutes. Once you have an account, log in to access the dashboard where you can create your integration workflows.
Upon logging in, click on the ‘Pabbly Connect’ option. This will take you to the workflow section, where you can manage all your integrations. Here, you can create a new workflow by clicking the ‘Create Workflow’ button, allowing you to set up your automation process efficiently.
In this section, we will create a workflow to autogenerate articles. Start by naming your workflow something descriptive, like ‘Autogenerate Articles Using AI’. Select the folder where you want to save this workflow and click on ‘Create’.
- Select a folder for organization.
- Click ‘Create’ to proceed.
After creating the workflow, you will see two boxes labeled Trigger and Action. The Trigger will be the first step that initiates the workflow. In this case, select ‘Google Sheets’ as your trigger application and set the trigger event to ‘New or Updated Spreadsheet Row’. This will allow Pabbly Connect to monitor your Google Sheets for any new topics added.
3. Setting Up Google Sheets with Pabbly Connect
Next, you need to connect your Google Sheets to Pabbly Connect. To do this, copy the Webhook URL provided in the setup. Head over to your Google Sheets, click on Extensions, and then navigate to Add-ons to install the Pabbly Connect Webhooks add-on if not already done.
- Open Google Sheets and go to Extensions.
- Select Add-ons and install Pabbly Connect Webhooks.
- Paste the Webhook URL in the initial setup of the add-on.
Set the trigger column to the final data column where new entries will be added. For example, if your data is in column A, select that as your trigger column. After completing the setup, click on ‘Send Test’ to ensure everything is configured correctly. This step ensures that Pabbly Connect can receive data from your Google Sheets.
4. Integrating Open Router with Pabbly Connect
Now, let’s set up the action step using Open Router. In Pabbly Connect, select Open Router as your action application and choose the action event ‘Create Chat Completions’. Click on connect and add a new connection by providing the necessary API token from your Open Router account.
Once connected, you will need to enter the HTTP referral and select the model you want to use, such as GPT-3.5. Map the topic from the previous step into the content area where you specify the prompt. This allows Pabbly Connect to generate an article based on the topic provided in Google Sheets.
5. Finalizing Integration with Google Docs
The last step is to connect Google Docs to Pabbly Connect. Add another action step and select Google Docs. Choose the action event ‘Create a Blank Document’. Connect your Google Docs account and specify the document name using the mapped article title from Open Router.
After creating the document, add another action step to append a paragraph to the document. Map the document ID from the previous step and insert the generated article text. This finalizes the integration, allowing Pabbly Connect to create and populate your documents with AI-generated content.
In this tutorial, we explored how to use Pabbly Connect to autogenerate articles using Google Sheets and Open Router. By following the steps provided, you can set up a seamless integration that automatically creates documents based on new topics added in your Google Sheets. This process showcases the powerful capabilities of Pabbly Connect in automating your workflow efficiently.
