Learn how to easily auto-post WordPress posts to Telegram in minutes using Pabbly Connect. Follow this detailed tutorial for seamless integration. Follow this definitive guide to creating powerful automated workflows with straightforward, efficiency-focused solutions that save valuable time.
To auto-post WordPress posts to Telegram, the first step is accessing Pabbly Connect. As an existing user, you can sign in to your account. If you are new, click on the sign-up button to create an account and receive 100 free tasks each month.
Once signed in, navigate to the Pabbly Connect dashboard. Here, you will create a new workflow by clicking on the ‘Create Workflow’ button located at the right-hand corner. This is where you will set up the integration that will allow WordPress to communicate with Telegram.
2. Creating the Workflow in Pabbly Connect
In this section, you will set up the workflow to auto-post WordPress posts to Telegram using Pabbly Connect. After clicking ‘Create Workflow’, give your workflow a name, such as ‘Auto-post WordPress post to Telegram in minutes’. Select the folder where you want to save this workflow.
  • Select the folder for organization.
After naming your workflow, you will be directed to a window that consists of trigger and action settings. Pabbly Connect allows you to define a trigger, which in this case is WordPress, and the action, which will be Telegram. This setup is crucial for the automation to function correctly.
3. Setting Up Trigger and Action Applications
The next step in using Pabbly Connect is to set up the trigger and action applications. For the trigger application, select WordPress and choose the trigger event as ‘New Post Published’. This means that every time a new post is published on your WordPress site, it will initiate the automation.
For the action application, search for Telegram and select the action event as ‘Send a Text Message’. This configuration ensures that whenever a new post is published, a text message will be sent to your Telegram channel. Confirm that both the trigger and action events are correctly set up to proceed with the integration.
4. Connecting WordPress to Pabbly Connect
To connect WordPress to Pabbly Connect, you will need to establish a webhook. In your Pabbly Connect dashboard, a webhook URL will be provided. Copy this URL and navigate to your WordPress account.
  • Go to WordPress Settings and select WP Webhooks.
  • Select ‘Send Data’ and choose ‘Post Created’.
  • Paste the copied webhook URL and save your settings.
After saving, create a new post in WordPress to test the webhook connection. This action will send data to Pabbly Connect and allow you to verify that the integration is working correctly.
5. Finalizing the Integration with Telegram
After successfully connecting WordPress to Pabbly Connect, the final step involves configuring the Telegram bot. Create a bot using Telegram’s BotFather and obtain the token needed for the integration. Paste this token back into Pabbly Connect to establish the connection.
Next, you need to specify the chat ID of the Telegram group where you want the posts to be sent. Ensure your bot is added to the group and has admin permissions to send messages. Once everything is set up, you can send a test message to confirm that your WordPress posts are being sent automatically to Telegram.
By following this detailed tutorial, you can successfully auto-post WordPress posts to Telegram using Pabbly Connect. This integration streamlines your posting process, ensuring that your Telegram audience is updated instantly with new content. Automating this process saves time and enhances engagement on your Telegram channel.
